sdes
There is a (now very rare) 901 cylinder, which is much smaller but we carry as a spare all the time. The three standard sizes are compared :
Larger Gaz refillable butane cylinders come in three sizes.
901 cylinder contains 0.454 kilograms (1.00 lb) of gas in a 161 mm (6.3 in) high cylinder with a 110 mm (4.3 in) diameter
904 contains 1.81 kg (4.0 lb) in a 188 mm (7.4 in) high cylinder with a 202 mm (8.0 in) diameter,
907 (the largest commonly used size) contains 2.72 kg (6.0 lb) in a 250 mm (9.8 in) high cylinder with a 202 mm (8.0 in) diameter.
Even in a packed van there's usually room for a 901....
Stephen
Stephen
