Alan Andrews
Hello to the technical buffs on here.
Yesterday was out for the day. Started first time and drove to first stop. Parked up and returned 1 hour later. Started first time. Drove to destination parked up. Returned 3 hours later to find that the engine will not start.
The starter motor does not click in. But can hear the ABS unit buzz.
Called AA out.
First thought was engine battery. Checked but all good.
Then checked the engine starter, starter Starter Inhibitor Relay and Starter Relay fuse.....quite a tricky task - having to squeeze between seat to access the central fuse panel. With target fuse at the very bottom of the panel. But all tested good.
Then tried to access the starter motor. But is is buried deep inside the engine bay and obscured by many components. So knocked it several times to see if this did the trick. No success.
In the end had to accept that the Cali needs to be recovered and dropped off at my preferred VW van centre. I still have warranty.
The Power Steering Pump was replaced just before xmas. So it has occurred to me that perhaps a electrical connector or connection may have worked loose, but I have no evidence to confirm.
I've read that there are known issues with T4 and T5 starter motors failing, but cannot find anything online to suggest this is a known issue with the T6.
My van will be collected and taken to VW tomorrow (Monday) when they reopen.
Any ideas?
Called AA out.
Any ideas?
