BlueCalifornia
I'm trying to buy a set of rims with winter tyres, but there is more to it than expected. Read many threads on this forum and online, but still a couple of things things I cannot figure out, base on the instruction on the sticker in my Cali T5 from 2007. Hopefully somebody else understands the logic in all of this
- Why does it only state "M+S" for the 215/60 R17C tyre and not for the others? Is this size specifically recommended for winter tyres? If yes - what is the reasoning behind?
- My spare tyre has size of 215/65 R16C. If i would fit a pair of 215/60 R17C tyres, those would have a slightly higher circumference than the spare. Would it then still be ok to use this spare?
- Why are the 235/60 R16 and 235/55 R17 sizes only indicated in the "XL" version and not the C version?
- Pressures between the "C" and "XL" tires are significantly different. Why is this?
- Also no clue why the different sizes come with different loadindex...weight is the same in all cases?
- For the 215/60 R17C tyre, the tyre pressures are exactly the same for fully loaded or empty van. For the other tyres this isn't the case. No clue why.
- Is there any real disadvantage in using tyres with higher load index?
Furthermore I read in some tests that the winter tyres for van are all actually underperforming. Best ones being the Continental Van Contact Winter, Michelin Agilis Alpin and Pirelli Carrier Winter. So i'm wondering if after all, maybe i could also go for the Agilis Crossclimate instead.
