I
ive_california
I think that the problem with a Buzz California might be slightly deeper rooted. The 77kWh battery of the Buzz offers a range of around 250 miles. If you add the weight of a fit out (even if you're careful) you're going to probably knock 10% off the range. If you then factor in motorway speeds and cold weather you are probably going to end up with a winter range of around 180 miles before even considering the drain from fridge etc. Obviously, you will also lose the diesel heater, so I think you would end up with a fairly poor camper van experience and the platform won't allow much latitude in the fitting of a larger battery to compensate.
So, I suspect the most viable proposition will be to base the next California on the new Transit/Transporter platform.
Make that 120 miles in winter. Ev's are a disaster in the winter. But to each his own...
Verzonden vanaf mijn iPhone met Tapatalk
