greenp
- Messages
- 228
- Vehicle
- T6 Ocean 150
Hi all, has anyone piped up a 4.5kg calor gas bottle (Butane) to a cooker in a California T6 ? I know it won't fit in the same place as the 907, but that's OK.
Many Thanks Paul
Many Thanks Paul
not done, but considered. Logically quite easy to do. You will not be able to close the rear cupboard completely, unless you are ready to drill a hole for the pipe to pass through.Hi all, has anyone piped up a 4.5kg calor gas bottle (Butane) to a cooker in a California T6 ? I know it won't fit in the same place as the 907, but that's OK.
Many Thanks Paul
1) morning economical using 4.5kg.What problem are you trying to solve?
If you do locate it in a new place will you be happy to lose the safety of the sealed enclosure and the gas “drain” beneath the cylinder?Hi all, has anyone piped up a 4.5kg calor gas bottle (Butane) to a cooker in a California T6 ? I know it won't fit in the same place as the 907, but that's OK.
Many Thanks Paul
