E-bike Charge - Not on EHU
The ecoflow battery will only charge at 100w/hr via the cigarette lighter socket ....so around 6-7 hours of driving to charge from empty. What I havnt tried (yet) is charging from the leisure battery when stationary on a sunny day...in theory the solar input from my set up should keep pace with the draw on the leisure battery.
@leeb thank you, interesting, so recharging takes longer than I thought.
I wonder how long it would then take a fully charged Ecoflow to then recharge a say 50% discharged 500w ebike battery?
On solar, which I was also considering, there are the standalone solar panels that Ecoflow supply (110w or 200w I think) or the larger roof mounted kit (up to three panels) from Roger Donoghue. It would be interesting to know how much faster the Ecoflow recharges with either of them joined in, as you refer.
@leeb I wonder how long it would then take a fully charged Ecoflow to then recharge a say 50% discharged 500w ebike battery?
That will depend on the bike's charger. My partner's 6A Giant (Yamaha) charger runs much faster than my 2A Orbea (Shimano) one.
Bike charge time is, of course, dependent on the output of the mains charger. Providing this is within the capacity of the ecoflow to deliver (my bike charger has a150w output so well within the ecoflow specifications) then the charge times will be the same as if plugged into the mains .
The ecoflow has a max capacity of around 700watts so the charge time, in hours, from the solar panel will be approx 700/watt output from your solar array.
Hope of help
Hope of help
Very helpful: 70 now, I feel like I am back in physics class, listening to Dr Sewter explaining what I should already understand, but it is a pleasant feeling - a little like riding a bike again as I do now, having been hardly near one for 55 years. Thank you for finding the time to respond.
I think an Ecoflow is the way to go.
I am thinking of an eco flow river 2 max to charge my eCycle Bosch battery. Picture of the battery and the charger attached.
Will this power bank charge my battery overnight? Or during the day if I get the solar panels?
Many thanks for any input.
It depends how flat your bike is going to be.
Generally you want your battery to work after it's cycle life has been reached so work on 80% capacity. So 410Wh. Assume 90% charging efficiency with inverter. So 369Wh. And you probably don't want to discharge to zero, let's make the discharge limit 15% .
You have 315Wh charge available from the battery for the lifetime of the device. Your bike battery is 625Wh.
Thanks for the reply, @yossarian
Bit uncertain about what you mean. Am I correct in thinking that this EcoFlow River 2 max will not work? And I need a more powerful EcoFlow version?
For the lifetime of the ecoflow you can rely on getting a charge from it's battery of about 315Wh going into your bike battery which has a capacity of 625Wh.
Wh are to electricity as liters are to diesel. So the ecoflow battery is good for about a half battery charge of your bike over it's lifetime.
More optimistic estimates are possible but the battery will degrade over time so it's wise to consider if it will work with a degraded (3000 cycle) battery. Also discharging the battery to zero will accelerate the wear on it. Typically we use a limit of 15% on a LFP battery to avoid going into the region where battery wear is high.
Okay, I get it. 1000 thanks @yossarian The eco flow will be fine if 100% charged up and applied to the the bike battery to charge it when c.2/3rd power is remaining in it.
Probably better to consider a larger capacity EcoFlow product (?)
It will work fine...I charge my specialised 350 watt battery with ease (speed of charge is limited charger specification)...your Bosch battery is larger but will rarely, if ever, be 100% discharged
The smaller Bosch 2A charger does appear to work with the T6.1 300W inverter. The charger input is 210-230v at 1A so a max of 230W and even if there is a higher peak wattage on startup, it does not appear to be a problem. The charger does not switch off or make any weird humming noises.
I have a 110Ah lithium battery and I estimate that I would need 75-80% of this capacity to fully charge an 800Wh ebike battery, so I would need to carefully manage the capacity to still have some juice for fridge/heater etc. The 2A battery is also super slow and would take about 12 hours to fully charge it, but I would need an inverter upgrade to be able to use the 4A charger.
I thought this info might be useful since the question of ebike charging does periodically come up.
I also use the 2A travel Bosch charger successfully haven't tried the 4A so thanks for confirming it would be too much load. I only use mine for topping up whilst driving.
Actually, I'm not really an expert here. The 230V x 1A = 230W is the max theoretically possible input power. For the 4A charger, which I assume is 230V x 2A = 460W, it would be too much for the 300W inverter.
However, the more realistic normal changing input power to the charger is calculated by working out the output power (in this case 36V x 2A = 72W) and back calculating with an efficiency rating of the charger. Assuming the charger is 85% efficient, this means the input power is about 85W, which is well below the 300W max of the inverter. In theory, the 4A charger could work (170W total) but not sure.
Does anyone know what will happen if I plug in the 4A charger and it overloads the inverter? Does it just not work, or will it blow a fuse or something?
FYI the control panel in the van says it draws 8-9A from the battery when charging, which works out for the power numbers of 85W:
Assuming inverter is 80% efficient, power input for 85W output would be 106.25W / 12V = 8.85A.
depends on type of inverter, pure sine wave is best, I expect the VW one to be the cheapest available, so cheap square wave, so 85% is at the very best case, more likely 75% efficient at probably half load.
If it gets warm/hot this is the best tell of the inefficiencies involved, normally expensive ones will have a thermal and current resettable trip inside when you overload them.
I charge an electric moped/scooter off of an ecoflow unit plugged into the 12v socket in the front when the vehicle is running.
