Plastic Pipe by Gas Cylinder
Viktorgeorge
Viktorgeorge
Starlight Blue Ocean 4Mo MY2023 older bellows
Suffolk
T6.1 Ocean 204 4 motion
I am trying to work out what is this coiled piece of plastic pipe (with fabric inside) - coming, apparently, out of the clean water tank.
Can someone help me?
I feel like I should cable tie it out of the way.
Looks like the water pump power cable, should just push towards front of van out of way.
Maybe you've mentioned it elsewhere, but whose gas cyinder, from where and what did it cost?
Leisuregaz, cylinder model 007. Matches the Campingaz 907 which I was looking for but no-one local (Felixstowe) had 907's in stock (there are issues apparently).
Leisuregaz was £59.95 full including the cylinder, the latter they (Levington Marina Chandlery) will give £10 back if it is returned. Refills of Campingaz are apparently £30-40 but of course you need a 907 cylinder which I could not find and there were none at the Campingaz local outlets (I rang around).
Apparently Leisuregaz in UK owned whilst Campingaz in American owned if you have a preference (I do though not obsessively).
