I
icic
It appear the wood floor panel (by the back bench) under the Lino coving has cracked as putting any weight on it it flexes a great deal, (which it did not do before) far more than the other side of the rail. Standing on it feels like you might go through it. I think this happened when a knuckle of a stand was put on the floor and a lot of weight put on top of that, giving in effect a large weight on a small surface area, hence why it’s appeared to have cracked the floor. I can’t see any crack as the plastic floor covers and damage.
I have a few questions about this. I think to replace this means removing everything in the van, kitchen unit .. everything. Has anyone ever done this ? It’s still under warranty (just) but worry that the dealer taking everything out they won’t ever get in back again as a factory fit (I have found this to be the case with other repairs the dealer has made). I am minded to just leave it, and watch my step.
However my other question has anyone ever seen underneath the floor, how deep is the cavity under the wooden floor panel to the metal floor of the van. I ask as if it’s not far then any flex in the cracked floor panel would hopefully hit the metal floor before further breaking, leaving a spongy floor but no danger of going through it, if the cavity is shallow it hopefully be OK to leave it ? Be great if anyone has any insight into this
