dspuk
Dave
Hi,
Have recently and with sucess, albeit taking several days and a lot of swearing, installed a BlackVue DR900X front and rear cameras with all cables fully threaded and hidden.
Not my question - just a flex.
I have it happily connected to perm (to the starter battery) and switched power in the fuse box, no issues there and works fine. This unit has the in-built battery protector which I have set to 12V and after about 24h on time-lapse mode the unit switches off to save battery. So far all good, all to spec.
But - I also have a 100w Solar panel fitted to the roof (Roger version) which happily trickles the leisures through the day, even in winter, but sits at float most of the time as there is nothing to (re)charge.
It occurs to me that, as the panel sits and charges the leisures anway, if I have a low draw on them from the BlackVue that is permanently topped up by the panel I could run the BlackVue in parking mode indefinitely as the top up would always be more than the draw.
Finally - a question - is there an EASY way for me to get the perm power on the BlackVue connected to the leisures? Without having to dismantle the van and feed a wire under the carpet. Ideally in the main fuse box.
Tagging @Loz as they seem a guru here.
July 22 6.1 Ocean.
TIA. DP
July 22 6.1 Ocean.
TIA. DP
