Allen key size for key fob
P
phil keegan
Newcastle
T6 Coast 150
Does anyone know what sized Allen key (or similar) I need for a tiny screw on my key fob that is working loose?
It should be a roll pin, simply press it out / back in with a suitable size implement, it is an interference fit so will require some pressure.
edit: a tiny screwdriver works
Phil,
tried to PM you, cant as you are not a VIP Member.
you may want to edit your photo to remove the key part, the close up of the key is sufficient to identify the key type and allow a spare to be made !
There are companies who will reproduce a key from such a photo. It may represent only a very small risk, but it is a risk nonetheless.
If your vehicle is stolen via the key you are not insured
:thumb
Phil,
:thumb
When I’ve worked out how to I’ll delete the post
Not sure you can edit if you are not a VIP !
I’ll report it to @calikev and ask for the post to be removed for security reasons for you.
Edit: reported your original post
edit : get yourself signed up to VIP member, it supports this great site & resource
Thanks again.
I previously accidentally ended up with a VIP Tapatalk account rather than one for the club!
Definitely will ‘join up’ and support as ideas, solutions and general information have been excellent
Thanks pin pressed in with a fork handle
