salbaderbrighton
Our 2008 California 2.5 TDI automatic has developed a new problem.
I press the unlock fob, car unlocks.
I open the driver’s door - hazard lights start flashing as if I tripped the alarm (no horn alarm). I close the door and open it without locking it hazard lights stop, I close it again and open it hazard lights start flashing.l
If I then turn on the ignition windscreen wipers start running at full speed. When I turn the ignition key further nothing happens the car does not start
No extra warning lights everything on the dash is as usual, just the windscreen wipers going at full speed – all as usual – glow plug symbols come on and switch off as they should as all other warning lights
If I change the windscreen wiper to interval it will do that – if on off it will –
go at full speed as long as the ignition is on
The Hazard lights can sometimes be switched off manually
Light switches, electric windows etc all work fine.
To me it looks like as if one of the control modules has had some kind of fault (water ingress?) causing currents to flow where they should not
Has anybody else experienced such a fault? Anybody know which module is responsible for hazard and wind screen wipers and where I would locate it in the van?
Thank you for your help
