Got the kitchen drawers and rear tray from the club shop.
Also added some anti slip matting to the shelves in the kitchen and rear cupboards.
are these additional drawers easy to fit? how much?
vwcaliforniaclub.com
How are they fixed to your roof please? Bonded?
Heavy duty velcro and removable with a warm heat gun, sounds daft but works brilliantly. I did a fair bit of experimentation with diffrent methods but this worked out the best. Didnt want anything that raised the roof hieght.How are they fixed to your roof please? Bonded?
Not routed yet but guessing down the back of the wardrobe, and ill let you know when they fall off…You've probably discussed this in another thread, but how have you routed the supply cable to the batteries?
Have you tested your velcro fixings in a wind tunnel replicating speeds of 80+ m.p.h.?
But in through the roof, as opposed to the Roger Donoghue route through the rear door grommet?Not routed yet but guessing down the back of the wardrobe,
Yep….But in through the roof, as opposed to the Roger Donoghue route through the rear door grommet?
Ha ha - we started slow too, but that soon changed!Newbies so starting from scratch
Today we received …
Levelling chocks
Pop top bellows bungee
Hook up cable
Hook up adapter (for home)
Rail load anchor (for dog)
Collapsible Colander
The outstanding list is long , but it’s all very exciting
.The list is endless..! I'm just totting up what we've bought in the last few weeks since we got the Cali (and not counting all the stuff we bought while waiting for it - 15 months..!) its at around £1500..!Newbies so starting from scratch
Today we received …
Levelling chocks
Hook up cable
Today we received …
Levelling chocks
Hook up cable
Ok thanks for the tip . I will research the bungee some more.Ha ha - we started slow too, but that soon changed!
I’m sure you will have researched this, but I would not advise fitting the bungee to the pop top. We got one ahead of getting the van, and it could have been a contributing factor in pulling the roof canvas away from the van in one corner. The roof canvas folds perfectly without it.
It arrives next week and TBH arrival has taken me by surprise . Am playing catch up nowI have a long list too. Better should start now buying stuff. Even if the cali has not been orderd yet.
Ok 2nd immediate reply on the bungee, so I will hold off.The list is endless..! I'm just totting up what we've bought in the last few weeks since we got the Cali (and not counting all the stuff we bought while waiting for it - 15 months..!) its at around £1500..!
Just a thought, you mention the pop-top bellows bungee. In our two weeks experience of owning the Cali, I don't think you'll need the bungee. The pop-top folds very well on its own, there are some stiffeners in the sides that pull in when it comes down. I have heard that a bungee may pull the pop-top away from its mounting points in the roof, so tread with caution.
The rest of your list is a good start, but it wont end there..;-)
Here’s a thread to look at…Ok thanks for the tip . I will research the bungee some more.
Only added it to our list as the “try before we buy” rental van had one and said it was to avoid the canvass being caught and ripped
Cali ownership is definitely one big learning curve
We upgraded to the same wheels a while back, fitted with Michelin Cross Climate 2's.
To be honest I can understand a rental van having a bungee fitted, to protect against the less careful users. It used to be more of an issue on older models, but I think the only failure mode on the newer canvas would be a strong cross wind bellowing out the canvas. We have eyes on the canvas each time we lower it, just to be sure.Ok thanks for the tip . I will research the bungee some more.
I also ordered the same carpet after seeing the pics. Someone should be on commissionOrdered exactly the same carpet set as yours, should be here soon…;-)View attachment 100363
Have you seen the California Time video about CamperVanCarpets..?I also ordered the same carpet after seeing the pics. Someone should be on commission
Spooky! - Ive just ordered the same! they look great and Ali was so helpfulOrdered exactly the same carpet set as yours, should be here soon…;-)View attachment 100363
