R
Rab
Ok..Just recently completed the earth shunt fix on my T5 SE174. Had the usual heater issues whilst on batteries. So fridge out ,shunt done ,fridge back in and now the heater working perfectly on both batteries and EHU.
A week later I went on short trip and noticed my fridge was not working on batteries nor was my tap/waterpump [ they had been working after the shunt fix] When i tried to drive off with the fridge switched on my control panel sounded an alarm with a cable warning. The panel seemed to think I was on hook up.
When I got home I put it on EHU and both the fridge and tap working fine. However with hook up off they still would not work on batteries. I then noticed the EHU was not charging my batteries. They do charge off the altenator. Confirmed this with voltmeter. Both batteries were new last year and both reading 12.6 v. It was then I discovered a blown cube fuse. Thinking this was my problem I replaced this but I still have the same issues.
I have tested all fuses under passanger seat and all fine.
Checked the connections to battery charger and have even stuck a voltmeter on the input cable to the charger and its getting 240 v. Fuse above charger cable looks fine and tested with meter.
I have even taken the fridge back out and had a look inside the charger for signs of damage. It all visually looks good. The 20 amp fuse inside the charger is fine.
This has done me Im at a loss. Van batterries wont charge on EHU but will on alternator. Fridge and water pump wont work off batteries but they do on EHU. Still get power to 3pin plug at sink. Heater works fine off the batteries and EHU.
I think I have tried everything. Suppose it could be a new charger but would the charger affect the fridge and waterpump.
Anybody got any ideas.
Much Obliged
Rab.
Much Obliged
Rab.
