jeffThunt9366
Hi all,
quick message from a new member; I found the site whilst searching Google for advice on a permanent install for a dash cam. Followed the advice in the very detailed post from a member Loz, thanks for the advice, all fitted.
I was a bit disappointed in the quality of the workmanship in the fitment of the overhead console: I have a 2019 Ocean, when fitting the overhead console, VW over torqued the two front mounting bolts splitting the plastic around the bolt holes, one of the front plastic mounting points had also snapped clean off.
This was the first time the console has been removed from new. Fortunately superglue and washers provided an adequate fix.
I fitted a Garmin 67W using the Garmin parking mode cable; it was a very tight fit, but I managed to hide the converter/control box away on the left side, most of the extra cable I put under the headlining above the windscreen.
