Christine Kirk
- Messages
- 211
We have an issue with our California Ocean supplied and serviced by JCT 600 Sheffield.
On the 23rd of May we dropped off our California at the Sheffield van centre for a service. It was driving fine and didn’t pull to the left; the front tyres showed no signs of scrubbing off / feathering on the shoulders. The safety check done on the 23rd of May confirms this.
The agent found that the rear oil seal on the crank was leaking and would need replacement. Due to the lengthy nature of the job the workshop couldn’t undertake the work until the 21st June but would try and fit it into their schedule if space became available. The work was done and the California returned to us in late June.
On driving it we found a pronounced pull to the left and the tyres gradually feathered on the shoulders. We drove the vehicle for short local journeys for a few weeks and only on the 5th of August did we use it for a run to London. On joining the first main road it was immediately apparent that something was wrong with a loud flapping / banging noise coming from the front wheel area. We stopped and investigated thinking it could be the awning working loose. It wasn’t the awning ,the noise disappeared after a couple of motorway miles!
On our return we took up the matter with JCT600 and arranged to take the California into the Hull van centre for inspection. The technician at Hull confirmed that the steering was pulling to the left, it was then agreed that the Sheffield van centre would sort out the problem.
We left the California with Sheffield Van Centre who were going to get to the bottom of these two issues.
The wheel arch liners on both side have been replaced ( they hadn’t been re installed fully and the noise on the motorway was the tyres wearing the bottom edges away!!
They have done a 4 Wheel alignment and for some reason re aligned the steering wheel.
On collecting it on Saturday 20th August the steering is still pulling to the left and is still hard work to drive! The Steering wheel is now at an angle and the tyre wear is making the shoulders wear!! new tyres will be needed but only when the steering issues are resolved. We are now unsure about the van centre being able to deal with these issue!
Meanwhile our T4 Carravelle plods on at 270K and serviced by our local workshop.
The California is due to return to the Sheffield Van Centre on Tuesday for them to again try and identify the steering fault, which is linked to the work they have done inJune disassembling the engine / gearbox to replace a seal.. 3 months of messing about and still a faulty steering and a loss of confidence in the process!
Anyone have any ideas as to what it could be?
