Californication69
Bill
Put in my order for a 6.1 4M Ocean.
DTD have mentioned, at present, they cannot order with the optional electric sliding door.
So should I order without it.
It was going to be a “nice to have” rather than “needed”
I understand they are troublesome after 5 years and need maintaining.
Other questions I’d enjoy your input on.
Cheers
If I choose Heated windscreen with heat reflecting glass £528
It removes Acoustic package with heated windscreen which is the same cost £528.
What’s the difference between the two packs.
Is it worthwhile having the increased alternator capacity if I’m having solar panels from Roger ?
What’s EU2 option at £96
Is it worth having high beam package ?
Will install the Lazer lamps in the front grill for country lane zombie killing :/
Traffic sign recognition if I always use Waze ?
Options on colour of bellows, stay with Grey on a Met Black?
What’s the Pro upgrade consist of with regards the discover Media?
If I don’t choose the Pro, Will it still have the digital cockpit as standard on an Ocean?
What is a bed extension with comfort mattress, if I remember correctly is it just the mattress which I don’t need as I use a S2S ocean cut out self inflating mattress.
4 keys are worthwhile as can pop one in a safe underneath. Ghost2 will be installed, so even if they locate key, they cannot start it.
Is the direct tyre pressure monitoring system worth £186?
I’ll know if I have a leak as it has tyre inflation warning as standard ?
Cheers
