K
KBR
Hi All,
I purchased a drive away awning recently, specifically the Kampa Cross Air. I hook it up to the van with a figure of 8 and kador strip to the slot under the housing of the factory fitted awning on my T5.1.
I figured the best way to attach would be to unwind the Cali awning a little, slide the kador strip in place, attach the drive away awning, then fully wind back the Cali awning. This all seemed to work well, but then I found that whenever I wanted to open and close the van door, it was catching on the Kampa awning and was a real faff to keep holding it out of the way so I didn't damage it.
It may be a silly question, but what do others do? Do you leave the wind out awning open a little with the drive away awning attached? Is there a technique with door opening and closing that I'm missing? I don't want to end up causing damage to anything.
Thanks!
Thanks!
