soulstyledevon
Kennycalifornia
- Messages
- 6,525
- Vehicle
- Cali now sold
Have you had your crank case oil seals checked ?Little update.
I’m organising the van for my next big trip.
Again, no oil light. On checking, it looked on the empty side.
So I added about 1l
Warm engine and re-checked after the litre was added. It looks to me, to be about half way up the Dippy.
Van oil change service Feb this year (22) covered 5500 miles. Little bit surprised it needs so much oil…?
Oil added
Should be easy to check with the drip trays removedNot yet.
I’m getting the cambelt changed next week and will ask the question. Is it easy enough to check…?
It’s a visual check, they weep so leaving a tell tale sign of oil and crud .Not yet.
get both ends checked , VW have updated the seal with a redesign
are you still in warranty?
If you shine a torch down the engine bay you should be able to see if there is a pool of oil on the undertray.Not yet.
French garage report the oil levels to be well below minimum levels…
did you get an oil level warning prior to the incident?
oil checked 1100 miles prior ?
if so that would have had to use several litres In the following 1100 miles !
Blue smoke ?
