Ch1pbutty
Dometic CFX3 35 Portable Compressor Cool Box and Freezer.
Excellent condition, complete with both leads (240v / 12v) & instructions.
(Display is unmarked. Green image in photo is the reflection of our garden hedge!)
Collection only from Burgess Hill, West Sussex
FEATURES
FLEXIBLE POWER OPTIONS
Powered by AC or DC
RUGGED CONSTRUCTION
Fender frames protect the unit from damage
EFFICIENT POWER CONSUMPTION
Optimised VMSO3 Compressor cooling technology
USER-FRIENDLY INTERFACE
The stylish, high-gloss TFT LCD user interface displays operating status
CONVENIENT CFX3 APP
Temperature control and performance monitoring via CFX3 App
EASY TO CARRY
Strong aluminium carry handles
...AND MORE
General
SKU number 9600025325
Model CFX335
Model on label CFX335
SKU replaced by 9600029524
Scope of delivery 1 cooler, 1 manual, 1 Connection cable for 12/24V connection, 1 Connection cable for 100-240V connection, removable wire baskets
Single or Dual Zone Single
Product Description Portable compressor cool box, 36 l
Refrigeration technology Compressor
Dimensions
Dimensions product depth 694 mm
Dimensions product height 407 mm
Dimensions product width 398 mm
Net weight 16.9 kg
Total volume (IEC 62552-3) 36.00 l
Electrical
Input voltage (AC) 100-240 V
Input voltage (DC) 12/24 V
Rated input current (AC) 0.94A at 100V, 0.39A at 240V A
Rated input current (DC) 7.5 A
Rated input power (AC) 50 W
Input frequency 50/60 Hz
Performance
Refrigerant, type R134a
GWP 1430
Refrigerant amount 38 g
CO2 equivalent 0.054 t
Energy consumption (DC@5/25°C) 0.47 kWh/24h
Annual energy consumption at AC (EN62552-3:2020) 44 kWh/a
Energy efficiency class (Regulation (EU) 2019/2016) C
Climate class (EN62552) N/T
Insulation Thickness 55.00 mm
Insulation Type PU (Polyurethane)
Additional
Colour Slate / Mist
USB Port 5V, 2A
Connectivity Type Bluetooth, WiFi
Basket Yes
Threaded inserts in base for mounting M6
Drain plug Yes
Anti-condensation coil Yes
Interior light Yes, LED
Certificates ECE R10, CB, CE, GS
Cable length supply cable 2.00 m
Dometic CFX3 35
This ultimate powered cool box allows you to take more of the food and drink you love, wherever you go. Its robust design is built for tough outdoor use. Enjoy efficient cooling with convenience thanks to a mobile app which puts control of your Dometic CFX3 at your fingertips. Go further, stay longer, and experience more.THE POWER TO BE PRESENT
With the Dometic CFX3, you have control of your outdoor experiences like never before. The CFX3 gives you the power to change your state of mind and put your well-being first. On-road, off-road, in the country or the back garden, your ordinary and extraordinary adventures will be fuelled by safer food, less waste and more confidence, giving you the power to be present in any moment.
FEATURES
Powered by AC or DC
...AND MORE
- Generous total volume of 36 l
- Heavy-duty yet lightweight ExoFrame construction with fender frame protected edges and aluminium alloy handles
- Powerful VMSO3 compressor cooling technology efficiently cools between +20 °C and –22 °C
- Easy-to-read High-Resolution Colour Display and soft-touch buttons enable seamless control and monitoring of cool box performance
- CFX3 App allows temperature control via WiFi or Bluetooth and provides performance history
- 3-stage dynamic battery protection system prevents dead car battery or allows deep draw on dual batteries
- Active Gasket Technology provides a superior seal to retain cool air and minimise power consumption
MAXIMUM EFFICIENCY AND CAPACITY
You can store an incredible amount of food and drinks in the Dometic CFX3 thanks to the internal compartment design. The CFX3 eliminates the dairy compartment, which means more room for all your favourite foods. Choose how you organise the space with a removable wire divider and enjoy a more even distribution of cool air with the extended evaporator, now on all inner walls of the unit.
TRACK COOL BOX PERFORMANCE WHEREVER YOU ARE
The CFX3 app provides a whole new level of control and connectivity. Download it for free in the App Store or Google Play Store, and connect to your powered cool box via your smartphone. Control and monitor the temperature of the cool box remotely, whether it’s from the front seat of your vehicle or in bed after a long day of exploring. Thanks to our user-friendly interface, it’s easier than ever to track the cooling status of your CFX3. If you happen to leave the lid of your CFX3 open, the app will send you a notification telling you to close the lid. While powered, the app keeps detailed records of the temperature and power consumption history, so you know your limits on your next journey. Go and explore. Enjoy peace of mind.
DIGITAL DISPLAY FOR EASY COOL BOX MANAGEMENT
The CFX3 series features an easy to read high-resolution colour display panel which states the temperature and status of the cool box. Several protection systems are built into the display, including a scratch-resistant cover and IP64 rated housing to protect against dust and water splashes, so you can feel confident wherever you go. The upgraded USB port is now located in the display panel for a faster and more ergonomic way to charge your portable devices. The intuitive user-interface displays the voltage, Bluetooth/WiFi connection status and temperature in colourful graphics. The operating settings of your cool box can be adjusted at the press of a button with a simple menu.
YEARS OF INNOVATION FOR COOLING PERFECTION
Take control of outdoor adventures like never before with the Dometic CFX3 35. Our market-leading VMSO3 variable speed compressor with optimised software ensures outstanding cooling and efficient power consumption. The CFX3 features durable fender frames that protect the edges of the cool box, making it ideal for rugged trips. Strong, spring-loaded aluminium handles make it easy to lift and carry. Set the cooling temperature of your CFX3 on the TFT display screen and pack all your favourite foods. Download the CFX3 app and roam free from worry. Once your CFX3 is connected through your phone, you can set the ideal temperature, and get a detailed history of energy and temperatures.General
Model CFX335
Dimensions
Net weight 16.9 kg
Electrical
Performance
GWP 1430
Additional
Colour Slate / Mist
USB Port 5V, 2A
Basket Yes
Drain plug Yes
