Borris
Really!Because it can take over a hundred miles somewhere among Lapland forest roads![]()
I love this forum, only here could an argument arrupt about getting a puncture.
I wonder if there are any heated debates like this at the Dorset meet with everyone face to face
Keep meaning to see if the Cali wheels will shift and/or put copper grease on the mating surface, but if I had a puncture it wouldn’t take much for me to call the pros
What happenedAsk me how I know.
What happened![]()
Don't forget your spareIf you take the wheels off regularly to clean them this doesn’t become a problem!
What, you don’t take them off to clean them????
To do this you really need to be under the van
Sounds good.Why? Short piece of 2x3 placed on the floor against the outside face of the tyre/rim, sharp blow with a lump hammer inwards. Done.
Deliberate? Ie same size of screw or nail in each?76,000 miles in our Cali, including 25,000 miles around Europe on a year long tour - and just one puncture.
And now three punctures on three different wheels in three weeks!
Hi all,
Had a puncture in front passenger side wheel last week. The culprit was a 2 cms diameter bolt!!
Neither Hubby or I were happy to drive it to our local tyre place over 10 miles away. BTW the tyre deflated when sat on bolt, rolled van forward a bit and reinflated tyre which then stayed up!!. Local VW car garage just up the road so gave them a call. Next day took it in thinking oh goody £25 puncture repair, oh no it wasn't, it was £155 for a new tyre. Why I hear you ask, this was because the tyre had been punctured and repaired before, and the puncture was within 16 inches of the previous one. This means by law it is not safe to repair it. So be prepared if you have had a repair, next time it might prove more expensive than you think!
You are correct. 18” wheels do not fit in the carrier. We also have a 17” in the carrier. Better than nothing!You can fit a suitably rated 17" spare on in place of an 18", as far as I'm aware, being careful of speed, etc. The circumference has to be the same for the speedo to work correctly with the different wheel sizes.
The danger of not having a spare would be if you are in a situation like @T6 CFO where your tyre is ruined and you can't use the liquid sealant. You would have to wait at the roadside till a replacement tyre can be found and fitted.
Our Cali had 18" wheels when purchased and we had a spare wheel carrier fitted and got a 17" wheel for it. As I'm pretty sure the 18" wheel doesn't fit the carrier.
Me too. It gives max access to the rear as neededI’ve removed the stops in bench seat so that I can have more space in the load area when required and access the tools by sliding bench seat all the way to the front.
Mike
We did exactly the same, spare wheel carrier and 17” (Winter) spare. We have 18” Summer alloys and 17” Winter. The book says a mix is ok in emergencies.You can fit a suitably rated 17" spare on in place of an 18", as far as I'm aware, being careful of speed, etc. The circumference has to be the same for the speedo to work correctly with the different wheel sizes.
