Anthony1
Too young to be old
- Messages
- 1,340
- Vehicle
- T5 SE 180
Oh no, been browsing 1 hours for a new Leatherman. Thinking about the Charge plus ttithrown out tools and heavy socket set for a leatherman wave which ive used umpteen times and never once used socket set![]()
Teflon is best.Gloss for a smoother finish???
They do exist for RC carsTeflon is best.
Beware:Several of these, light weight easy to carry and cheap and easy to replace,
they fit in the front door pockets when on the move.
Thanks Borris,Beware:
I used to keep a large plastic bottle of water in the front passenger door pocket of our first Cali SE. When I sold it I removed all of the vehicle contents and noticed what can only be described a localised burn marks on the door card of said door, behind where the water bottle had been stored. After much head scratching I concluded that the magnifying effects of the sun's rays had caused this damage. This isn't far fetched as it is apparently one of the recognised bushcraft methods of starting a fire in the outback.
fab3d.co.ukOmg! Where are those from?!!!
Hi @Bluebird ,Can I ask where you got them from ? They are just what I’m after.
We have a small but power bank, plus you can charge from your van's cables in the glove box and the plug for the inverter. No need for anything big. I also have a small fold our solar panel which can charge three phones at once.I'm not sure if this counts as a true Game Changer just yet as I haven't actually used it properly so far, but I'm hoping it proves to be the case.
After being away for 5 days without hookup over the Jubilee weekend, I ordered this as we got fed up trying to charge various phones / watches etc using the sockets in the shower block. Too many devices and too nervous about leaving phones unattended.
It can supposedly charge an iPhone 24 times, or a MacBook Air four times. It only turned up today, but with 3 USB's and one three pin plug, it should also enable me to work from the van more easily.
Is a lot smaller than I expected, so looking forward to testing this out.
Makes sense. I have a full toolset, sockets, spanners, even feeler guages etc. Never used them. I have break down cover, really not necessary. But I will keep the breaker bar and socker to change a wheel. I'm not prepared to wait two hours for someone to come and change a wheel.thrown out tools and heavy socket set for a leatherman wave which ive used umpteen times and never once used socket set![]()
Who makes the under sink drawers?Slide out rear tray and set of drawers under sink (for a T6) but a Forum poster gave an illustration of how to fit them to a T5.
That’s great. Will do it when I get back, the rattling from the centre console is annoying.Hi @Bluebird ,
The cup holder is a cheap one off eBay. This is the one that I purchased - see pic.
The other two items are quadlock - see on quadlock site here -
Universal adaptor - https://www.quadlockcase.co.uk/products/universal-adapter?variant=4273835525
Wall mount - https://www.quadlockcase.co.uk/coll...adhesive-mount-twin-pack?variant=346965147666
Assemble them together and you have a good setup. Building one for the passenger side now too.![]()
Sent from my Pixel 6 Pro using Tapatalk
Do you mind if I ask what these are called and where did you buy them from?best £6 you’ve spent on the Cali ?
try adding some of these to the leg feet for even more secure pegging
vwcaliforniaclub.com
Have a look at this thread (more via the search )Do you mind if I ask what these are called and where did you buy them from?
Campervanbits , ie the club shop. Not cheap at £319 but makes life a lot easier. You also lose some storage space. I wouldn't go back though. They are designed for the T6. The sliding door catch is in a different place in the T6. But if you, very carefully remove a few mil from the door catch, it will still work and the drawers will also work. They are soft close too.Who makes the under sink drawers?
That does sound tempting.
Oooh no, missed that. I’m sure we’ll go back one day. Thanks for the tip.Did you check out the Preservatives museum…?
Is this what you mean?Campervanbits , ie the club shop. Not cheap at £319 but makes life a lot easier. You also lose some storage space. I wouldn't go back though. They are designed for the T6. The sliding door catch is in a different place in the T6. But if you, very carefully remove a few mil from the door catch, it will still work and the drawers will also work. They are soft close too.
Would you use this instead of awning tie-down straps, or at the same time as tie-down straps?best £6 you’ve spent on the Cali ?
