Jester
Nice reply Andy and in good time.Was in the same position re the tap last week. If you pull out the top under sink draw, - just pull out to full extent & then lift up the front edge & it should pop off the runners. You can then get to the cable that feeds the tap switch, I cut that. You can then put the fuse back in & have water working everywhere else. The shower hose enables that tap to reach the kitchen sink if needed.
I understand the new tap comes with a new cable. If not its only a 2 minute job to rejoin it.
