G
It's not that difficult, but you need some patience. And don't worry, you can't mess anything up, but you wrapping-foil. the paint isn't affected by the adhesive from the foil, as long as you use premium brands.Really impressive that this is something you can do yourself. I would love to do this, but I'd be to afraid to mess it up. Yours looks really nice, just as if it was factory made in that colour. Well done! Mooi gedaan!
Yes I’m afraid some Cali owners might be disappointed to see a caravan being towed by one. My Dad used to raise a finger rather than waves hand at caravanners squeezing down single track roads in Yorkshire!Used it to tow a caravan though Norfolk and Suffolk. Despite waving at 2 California vans no one waved at us. Does towing a caravan make us” persona non grata”? I get waved at without the caravan.
My caravan is no wider than the California. Very easy to tow but I too do not like narrow roads. The sat nav needs to be ignored when towing and maps used and the California is better for a lot of trips.Yes I’m afraid some Cali owners might be disappointed to see a caravan being towed by one. My Dad used to raise a finger rather than waves hand at caravanners squeezing down single track roads in Yorkshire!
Looks neat!! What brand are the mounts and panels?Sunday: Fitted the new and improved (with ventilation cutouts) solar panel mounts, new channel mounts and new panels.
i have had several vans ranging from T2 to my current T6, by far the worst wavers are T6 onwards
keep on waving, I’m regularly shamed by my Fam when I wave and don’t get a response![]()
Looks great should of got you to do my one for the joker.I made the Channel Mounts myself and templated the panel mounts for fabrication. (They’re just an evolution of the one I did back in 2019 - less weight more ventilation) Panels are 100w.
Solar panel has finally arrived, collect Monday so I can finish mine finally.
You have the angle when roof is upOn an average day, yours should charge faster than mine as the panel’s closer to the sun
I've drawn up the measurements etc for my shelving. Happy to send across, but as the other comments have noted you'll have to remeasure. PM me and I'll reply backYes, 6.1 on order so I guess the dimensions will be different. I’ll just wait till it arrives and measure then…
Mirror finish!
I use :Mirror finish!
What product/ process do you use?
and clay bar before polish and wax if you really want to work those elbows ..I use :
Jet wash : wet the whole vehicle, take off all loose material
Snow foam : Bilt & hammer car wash auto snow foam (best I’ve found, use a little to get a great pre clean, loosen dirt )
jet wash: wash off snow foam
hand wash : noodle mitt , either Autogylm or Halfords ! (two bucket method)
maintenance wax: autoglym aqua wax (unbelievable maintenance on a wet vehicle)
twice yearly : Mcguires ultimate wax + elbow grease
Once a year: remove tar spots (lighter fluid ) re wax
two bucket method to wash is a must & keep the dealer away from your van !
wheels : valet pro; billberry juice (excellent)
the trick is to remove as much grit / dirt as possible before touching the van, the built and Hamber is defo worth the cost, uses 90% less product than other more expensive snow foam , a little in a snow gun goes a long, long way & actually works ( unlike other high foam products)
The bilt and hamber does not foam to a high foam, instead it just works
www.beaulieu.co.uk
It was unbelievably clean and tidy surely a concourse winner, even underneath it was like new truly a credit to someone & great to see such a well looked after T1Love the T1’s
