2021 T6.1 12v Socket & Cigar Lighter Fuse?
VW1Camp
VW1Camp
Milton Keynes
T6.1 Ocean 204
Evening
Re: 2021 T6.1 12v Socket & Cigar Lighter Fuse?
Could anyone help with the location of the fuse that covers the 12v socket up on top of the dash in front of the driver and the cigar lighter.
As neither are working I’m presuming one fuse covers both?
I’ve checked the owners manual and unbelievably no fuse diagram
Thanks in advance
David
Evening
Thanks in advance
David
Normally those 2 sockets have different supplies. Dash top from the Leisure Battery. Blue 15 amp fuse under front Passenger seat.
Cigar lighter, normally engine battery with a 15 amp fuse in the Central Dashboard fuse board.
How did both sockets fail?
The fuses used and fuse box are fixed but the position of the actual fuse varies depending on the vehicle options fitted.
Thanks, not sure how they both failed if on separate fuses. Dash cam plugged in the dash one, cigar lighter never used so wouldn’t know if has ever worked. Cheers for the advice
Looks like I might need to go to a VW and they are a nightmare No 15 amp fuse under the passenger seat. Anyone else help please? 2021 204bhp if it makes a difference.
Thanks in advance
David
Thanks in advance
David
Have you checked the Dashboard Fuse Box? It might mean that both sockets have been wired from the Starter Battery.
If by the dashboard fuse box you mean the one under the headlamp switch, none of the 15amp fuses are blown… There is only one
Cheers
Cheers
There is aT6.1 Fuse List, provided by @Loz in the RESOURCES section. It's changed on the T6.1 - 20 amp fuses under the Front Passenger seat RHD.
So quick question I have a 2021 Cali Ocean and the two cabin sockets are always on regardless of ignition, is there a way to make the ignition switched ??
Thanks, all sorted I was the 20 amp fuse under the passenger seat, covers the 12v socket on the dash and the cigar lighter
Thanks again
David
For reference, it’s the same fuse and location for a 2022 150PS Ocean: 20A yellow fuse under passenger seat, one of 3, it’s far left nearest driver’s seat.
No, they are powered by leisure/camping batteries. So you are on to some serious electric engineering if you want to fix that problem. If you can settle for 5volt use the USB-c connector to the radio, or let the usb 5v control a relay switch on 12v.
secret lemonade drinker
Meoncoast
17K
Amarillo
Amarillo
powysjune
12K
