bgg1b
Hi everyone, I’ve looked through the forum and can’t see an answer to this so apologies if it is covered in another thread. I went to use the inverter in my Cali today for the first time.
It works and the plate seems to be fixed ok, but when I insert a three pin plug it does not seem to go all the way in properly and wobbles such that if you just move the cable a little on the device it interupts the power supply and you have to go an push the plug back in again. I’m currently holding the plug in place with an elastic band around the plug and wrapped around the handbrake which is not ideal.
So the question is do your plugs fit securely into the inverter or is there a trick I am missing?
Thanks in advance
Thanks in advance
