Fridge not working
P
pjor
Cumbria
T5 SE 180
Hi folks hoping someone might be able to help with a fridge issue.
Have 2008 Cali and fridge went on blink a while ago - could hear click when switching on at control panel but then switched itself off almost immediately. Removed Danfoss controller and sent to Penguin who diagnosed controller faulty and sent me replacement. I have just fitted replacement controller - had to remove fridge to get it back in - and when I turn on at main controller now there is nothing, not even click that tells you fridge has turned on. Have removed fridge again and checked that 3 pin attachment is good from controller to compressor and checked other electrical connections and still no joy. One thing I haven't yet done is checked fuse again (was first thing checked when fridge originally went on blink) because it's a pain to get at fuses under passenger seat.
Any help/suggestions much appreciated.
Paul
Paul
Check the fuse.
Passenger seat fuses. Turn chair through 90o and then slide towards kitchen unit.
Thanks for reply. Have just checked fuse - it's not blown.
Any other suggestions?
Have you cleared any Diagnostic Codes on the Control Panel?
Would you be able to explain how I do that.
Check Control Panel Diagnostics.
Control Panel Off and wait 30 secs
Control Panel On
Press and Hold R lower button and then press Control Knob for 5 secs.
New Hidden Menu . Scroll to VW Diagnostics.
If there are any codes shown, take note and then Reset/Clear.
Return to Main Menu.
Switch Off Control Panel using L lower button. Wait 30 secs and Switch On.
Try Roof/Heater or Fridge
Sorry for not posting again earlier, something else got in the way. Anyway, it's working now - didn't need to clear any faults on control panel. Not sure why it didn't start to work straight after I replaced and connected up controller. Maybe I just had to switched panel off and on again.
Thanks very much for your help
Hi all, not sure where to post as so many fridge threads. My fridge clicks on and then cuts off immediately. It did stay on for a while after insisting but since a year or so it has not worked. The light turns on and off, first question is if it is engaging, I assume the fuse is OK.
Second, VW diagnosed it was the thermostat, if so, where can I purchase a replacement and please point me to a thread where I can see how to replace.
I’m not much of a mechanic but your advice much appreciated.
Thanks!
Hi all, finally I have a resolution for the fridge. It is the Controller that has gone (after double checking) and I’m being offered a replacement, used one for £120. Does anyone know the price of a new one as it may make more sense to put in a new one know the fridge is out. Also, where best to purchase.
Cheers
Cheers
This firm has been used by Forum members with positive results.
Cheers. I was in touch with them early on but they are reluctant now to get so involved with Calis. The people I am using were recommended by Penguin as a reliable company in Norfolk and are 15 mins away from me. But as far as new parts are concerned I might try them again, thanks.
Hi WelshGas
Please would you share the name of this company in Norfolk. I have fridge problems!
TIA
Rick
Penguin were brilliant with my controller some years ago. A very reliable and proper company to deal with.
Why problems in dealing with Cali's now?
Hi WelshGas
TIA
Rick
I’m sorry I can’t help you . @Nacs who mentioned the Norfolk company hasn’t been back to the Forum since November 2025.
Maybe give Penguin a call for any recommendations of companies near you?
Hi all.
Fridge problems for me in my 2005 T5 Cali. While I am waiting to hear from penguin about replacing the controller,, does anyone have instructions for how to remove the controller pls? Thanks!
I just contacted them and they were super-helpful as others have found.
UPDATE they checked my fridge controller very quickly and found it faulty and sold me a new one. So far so good! Just have to fit it now...
