KGCali
Retired and still young at heart!
Great news, did you get the 10x9mm D shaped seal from the link I sent you on the other forum, hope it seals and slides ok. Put a hose on it and post an update. Good luck!Update! Window back in its frame with a new D-shape rubber sealing. That was the easy part. Still has no solution for the drain holes other than replacing the whole frame. For anyone considering renovating the sliding window here comes a couple of pics. But as mentioned I have no idea yet if the water will pour in. My hope is as long as it is closed (it seem to tighten against the frame) no water will ingress. Maybe naive. I am waiting also for a new mechanism. Also an easy work to fix. Replacement parts are cheap. View attachment 92239View attachment 92240
