Connector Recommendations?
s2bear
s2bear
london
T6.1 Ocean 204 4 motion
Hellooo
I’m purchasing a replacement solar panel which doesn’t have connectors fitted. My current single panel setup has the Delphi two pin connector. I may switch to a dual panel setup and am “connector curious” the Delphi is just slightly too big to fit in the roof channel and if I double up there will need to be be a two into one connection (undecided on the practicalities of that bit yet).
I see the MC4 style everywhere but they seem bulkier than the Delphi (?). I also see the Deutsche DT (which looks smaller) but don’t know if they’re suitable.
Any recommendations?
I'm using the Amphenmol AT-6 series , they are 100% compatible with Deutsche - which means the patent must have run out!
Thanks Roger, I’ll take a look.
Hellooo
If you don’t need to unplug it then use some blue through crimps and buy a electricians crimping tool.
