t6.1
I'm wondering if anyone knows what I'm doing wrong here, or if there's something wrong with the seat please?
In this video it shows using the front lever you should be able to move the seat along the rails:
It looks like the front lever brings up the front legs, but not the back ones. By taking the draw out I can get in and push the mechanism inside to bring up the back legs and it will slide, but I'm sure this isn't the correct method!
I've put together a video to show under the seat and the mechanism:
Other useful posts for reference:
vwcaliforniaclub.com
Thanks in advance.
how to fit the 5th seat
done the obvious and not found anything on the forum and checked utube etc with no luck so hoping someone here can help... have got a 5th seat for my SE which has the three rails, thought it might be a clip and go type effort like my old T4 bench seat was but no such luck. so far have taken up...
moving 5th seat
Hello, Has anyone out there found a knack to remove and refit the 5th seat? Im wondering if the back should be up or down, swivelled or not? At the moment, I fear im going to scratch the floor and rails. Thank you!
Putting in/taking out 5th seat - what am I doing wrong?
I've just had a 5th seat arrive for my T6 Ocean. I can't find any instructions anywhere. I've figured how to get the rail covers off and the seat seemed to slots into the grooves, however it won't slide back to securely fasten into the rails. Has anyone got any helpful hints for me please? Tony
Help needed please, removing 5th seat
So far I've not fathomed this out. I have removed the plastic end caps at the end of the rails, and moved the drivers seat as far forward as it can go. I have also folded the fifth seat down, and turned it around as per the manual. Problem is there is still not enough clearance to get the second...
Thanks in advance.
