Great @jMacdentOnce again not bought today but last year when waiting. Vango Tailgate Airhub Low for those trips longer than 2-3 days. Very quick to put up and take down. One valve. Me, wife, 2 boys & 2 border terriers.
How does it connect with open poptop.Once again not bought today but last year when waiting. Vango Tailgate Airhub Low for those trips longer than 2-3 days. Very quick to put up and take down. One valve. Me, wife, 2 boys & 2 border terriers.
Don’t sleep in it. Use it for changing, bikes, leaving stuff when off site.It’s a drive away, so just release the straps/ roof bar Velcro/ kador ( whichever you are using) and leave. Under 7kgs pack weight without the accessories. 75cm x 33cm x 33cm.Great @jMacdent
Do you use it to sleep in?
Can it be left on-site i.e. like a drive away awning?
What size is it when packed away?
Yes. You have to make sure that you don’t pull the tunnel connection too snuggly over the tailgate though. Little bit of trial and error at first but the awning size makes it easy to reposition.Can you shut the tailgate when it is up?
It works fine whether you use the throw over straps or in my case, using the built in velcro straps for roof rails with short bungee cords looped through the straps and around the back roof bar. The connection doesn’t go far enough over the roof to really be affected by the pop top when open.How does it connect with open poptop.
How do you prevent the tailgate from coming down, when someone is sitting/sleeping/eating under the tailgate?Once again not bought today but last year when waiting. Vango Tailgate Airhub Low for those trips longer than 2-3 days. Very quick to put up and take down. One valve. Me, wife, 2 boys & 2 border terriers.
The gas struts are not always able to hold the gate upright, especially during lower temperatures.
Regards from Amsterdam,
Marc.
I've found the tailgate stays up pretty well even when it's cool. I've got the VW shower tent stuffed in with one of chairs (which is relatively heavy) and the tailgate still stays up under the awning connection. There is little or no actual force/pressure applied to the tailgate by the awning tunnel. Although you can have the tailgate up all the time, it's not necessary to keep it up to maintain the height and shape of the tunnel. The throw over straps or velcro straps keep it taught. If you wanted to, you could pull the tunnel further onto the van which results in the tailgate becoming 'jammed' over the lip of the front awning airbeam roof structure but this would mean you couldn't close the tailgate without releasing the connection straps and moving the awning away from the van every time you wanted to close the tailgate.How do you prevent the tailgate from coming down, when someone is sitting/sleeping/eating under the tailgate?
Marc.
Your feet will cook in them !Ridge Monkey water shoes - in the anticipation of splodging temperatures soon! Bought from Campervanbits shop. View attachment 92562
I’m thinking of doing this upgrade. Did you go for the aftermarket runners? If so, was it an easy job to modify them?Have just fitted the extra drawer on the side on the bench seat-easy DIY job thanks to Californiatime video
Purchased this couple months ago, delivery due June 6th. Not sure if drive away is possible with adaption but usually stay put anyway. Roof can close and integrated mosquito net. Light and small. Will review when used.Once again not bought today but last year when waiting. Vango Tailgate Airhub Low for those trips longer than 2-3 days. Very quick to put up and take down. One valve. Me, wife, 2 boys & 2 border terriers.
Called out well sandcrest L tailgate awning.Purchased this couple months ago, delivery due June 6th. Not sure if drive away is possible with adaption but usually stay put anyway. Roof can close and integrated mosquito net. Light and small. Will review when used.
Outwell Sandcrest L - buy online direct from Outwell
Couples, families and friends will all appreciate the light weight, small pack size and extra space the ingenious Outwell Sandcrest L delivers for more comfortable van life. As a rear-mounted, fixed awning, with just one aluminium pole, it´s really light, packs away small and vehicle doors...www.outwell.com
These are great......clip to the lower part of the awning leg and run all night on the lowest setting.....Luci solar string lights, look well made and no batteries required.
First impression is vey good
three brightness setting (white version only )
looks a bit crowded there ?These are great......clip to the lower part of the awning leg and run all night on the lowest setting.....
