What plug?
Amarillo
Amarillo
Tom
Royal Borough of Greenwich
T6 Beach 150
The campsite in Spain says:
"Electric connection: Blue European plug for exterior. Adaptor required."
Is that this
Or this
I always carry B in the safe for emergencies. I think Italy has a lot of them still.
I expect “adaptor” is a mis-translation for hookup lead.
Anyway, I have four adaptors or leads.
#1 short European 2 pin to external round 3 pin.
#2 10m External round 3 pin to circuit breaker with 3x UK sockets plus 2x USB.
#3 short UK to round 3 pin
#4 10m standard hookup
Intend to run #2 into the driveaway awning for electric hot plate and kettle, then #3 and #4 from the awning to the van.
I'm surprised that you don't have a reversed polarity lead; still quite a common occurrence on continental sites.
I’m not sure it matters on any of the appliances we use: kettle and hot plate. We’ve used a small fan heater in the awning on a couple of occasions. Other than that everything is 12v DC and reverse polarity won’t affect the battery charger.
If we had a toaster it would be very dangerous if someone poked in a knife without unplugging.
Same as touching the element on electric fan heater with something metallic.
Its the only time that a reverse polarity is more dangerous.
You would have to be pretty stupid to do either.
The fan heater is southern Italian where three pin plugs are reversible.
I’m fairly (or very) ignorant about how domestic wiring works, but I can’t understand how reverse polarity can be a danger in that part of Italy.
The danger is down to the on off switch on the device. Worst case cheap toaster the switch only switches the live circuit. If correct polarity the +ve flows from the socket to the switch.
If switch is off anything beyond it is dead ie the heating element.
If reversed polarity the switch just stops the current flowing out of the toaster, so even if the switch is off the element is live, touch it with a knife/ finger & you compete the circuit, the current flows through you to earth.
Most devices are sealed so you can’t get access to anything live - it’s only toasters, the bar on a electric fire, the heating element on an electric kettle etc that are a risk. Even then it’s only a problem if the switch only works on the live wire. Most modern stuff the switch works on both cables.
Good to always carry both when you're over here in mainland Europe. At most (modern/large) sites you'll encounter the first one in the photo, but if you enjoy smalller, more remote campings or staying at farms, or parking up in urban environments, the second can be a lifesaver when looking or a hookup.
A …. because continental folk have hook up leads with B on the end and need an adapter for A.
Brian’s Dad
Shadrack
Gooldmike
5K
Gooldmike
Gooldmike
