winter air
Suggest you put a call in to Sinclair’s in Cardiff - they seem to know their stuff. I was in there on the weekend to enquire about a tyre flush and summer air refill. He said if I went for Welsh gas he’d throw in a good rimming in for free. Any reviews on Welsh gas? Is it worth the Premium? Will I still get the same promised mpg improvement when I drive in England?
I spoke to Sinclair’s and they can’t shift any of the premium stuff. Probably why, they’re throwing in the free rimming…
I now need rimming again , am I best replacing my wheels with steel ones ?
I’ve been told that rimming is most successful when you’re steeled for it. Cardiff has offered Welsh Gas as a special to newer members, but apparently it’s turned out to be just hot air extracted from chickens.
And there you have it from the expert as he relaxes in his " subsidised solar heated bath ".
What’s the best date to change Winter air? 1st April is just around the corner…
Best to check the long range weather forecast. I imagine it might be too late to get a booking for 1st April.
I agree with the "check long range weather forecast " . I was planning to change 1st April to summer air, but a winter blast is coming ... so will stay with the winter air for a few more weeks.
Cleaner, greener bike pump air.
You seriously went to Sinclair, Cardiff?
Looks very familiar, but a full inflation is (for me) a real workout for the arm muscles. Push 30 times, relax for a minute, repeat as required....half an hour later, have a cup of coffee.
In all seriousness,
i‘m seriously considering a serious upgrade, to seriously sort out the serious issue of this serious issue
That’s about right. 30 pumps is about 1 psi. I was inflating the tyres for heavy loads. From memory, rear from 41 to 45psi; front from 44 to 45psi. Total inflation 10psi ~ 300 pumps.
As well as cleaner and greener it’s sweatier and therefore smellier.
You seriously used the word “seriously” on this thread!?
Yes. Seriously. I doubt if they would even know anything about even “ a solar heated bath “.
Just pop your tyre pump in the freezer for a couple of hours before topping up your tyres ..
I just put the wheels in the freezer for a bit one at a time, far far simpler than messing about with a foot pump.
Andy, you know how I don’t like to be disagreed with, but once again you have out done yourself with that one. Absolute Genie ar*e
motacyclist
Hotel California
H
K
KevH
Meoncoast
AndyFromTheBrac
Jason wallace
6K
westfalia
westfalia
