Bumble The Van
As the others have replied normal for this vehicle. Any other vehicle and you would think this emulsion of oil and water (aka mayonnaise ) was clear sign of head gasket failure.Rather worryingly i thought i would check the oil on my new 6.1 ocean, its done 5k miles and is running perfectly but when i opened the oil cap there was this gook at the top , is this ok or should i be worried? Any help gratefully received thank you
By the way I am not one to be a health an safety freak, I do plenty of my own mechanics and get greasy, but I believe that mayonnaise is considered to be one of the most harmful to humans out of all the engine related goop. It is essentially a mayonnaise made from moisture, oil and engine blow by gasses which contains all the unburned nasties from the combustion chamber so best not to repeatedly get it on your skin.As the others have replied normal for this vehicle. Any other vehicle and you would think this emulsion of oil and water (aka mayonnaise ) was clear sign of head gasket failure.
Just as you have done extract with digit and clean
Point taken and good adviceBy the way I am not one to be a health an safety freak, I do plenty of my own mechanics and get greasy, but I believe that mayonnaise is considered to be one of the most harmful to humans out of all the engine related goop. It is essentially a mayonnaise made from moisture, oil and engine blow by gasses which contains all the unburned nasties from the combustion chamber so best not to repeatedly get it on your skin.
but when he stops again, more will build upDo a long trip and it should go away.
Similar to Marmite, really.By the way I am not one to be a health an safety freak, I do plenty of my own mechanics and get greasy, but I believe that mayonnaise is considered to be one of the most harmful to humans out of all the engine related goop. It is essentially a mayonnaise made from moisture, oil and engine blow by gasses which contains all the unburned nasties from the combustion chamber so best not to repeatedly get it on your skin.
I used to get tons of it in my bored out, tuned up mini when I was a lad, probably because my trips were short, breathers weren't up to the job and all that stuff that goes with fiddling with the stock setup. When I did a service, there would be an inch thick layer on the inside of the alloy rocker cover and I would wipe it out. It really stunk and wouldn't soak into the cloth properly. Just had to grab a hand full in a cloth and throw it in a bin bag. Wierd stuff ... yuk.Similar to Marmite, really.
No, not really if one avoided short trips where the oil is not getting hot enough to vapor out the condensation. Oil temps above 100C are perfect. But since it is still chilly outside the oil will probably stay at a lower temperature. In the summer most of the "mayonaise" will have gone.but when he stops again, more will build up![]()
Have never had mayonnaise in my oil filler cap but then I never do a short journey, always at least 40 miles one way.No, not really if one avoided short trips where the oil is not getting hot enough to vapor out the condensation. Oil temps above 100C are perfect. But since it is still chilly outside the oil will probably stay at a lower temperature. In the summer most of the "mayonaise" will have gone.
same hereHave never had mayonnaise in my oil filler cap but then I never do a short journey, always at least 40 miles one way.
