Tarquers
Visiting friends last night on the polish-Czech border only after driving 200m up their snow covered and frozen drive we discovered that there was no space to turn around as there had been a big dump of snow and their own car was stuck at the top of the drive.
When leaving after a few hours (more snow) started reversing down the drive and at the point where I had had a bit of trouble on the way in (I walked the drive before backing out) the van slid off the road and into a bank of snow, ending up with two wheels in a ditch and the drivers side (U.K. passenger) wedged against the bank. Luckily we slipped that way not the other as there were two lakes to the other side.
After much digging to remove the snow from under the body we got out but not without some effort. With traction control on, the drive system seems to aggressively spin the wheels even after releasing the throttle and 4motion only engages once there is spin, so at low speed, low traction the systems make things worse.
Using the diff lock and disabling traction control it is possible to rock the van backwards and forwards without wheelspin until there is enough momentum to go forwards or backwards to move. This works because the diff lock effectively engages the front and rear wheels together which gives 3 wheel drive and helps greatly.
The DSG is a major limiting factor in these situations, especially when moving from forward to reverse gears, needing to hold the van on the brake at the end of each rock rather than allowing momentum to help. The throttle response is also poor meaning that sometimes a lot of throttle needs to be used before the DSG engages power so you have to be heavy on the throttle and then let off quickly before spin happens. Only time I have missed a manual gearbox and if I was going to be doing this a lot, I would prefer manual.
Overall once the technique was mastered, we came out reasonably quickly and once back on the packed ice, handling and control were superb. I doubt full winter tyres would have helped much over the Agilis 4 seasons and otherwise these tyres have been fantastic in the snow. Very glad I packed a shovel and other bits of recovery gear. I would also recommend anyone buying a 4motion to spec the diff lock if you are planning on being anywhere near a decent snow fall!
