CaliSwede
Hi all,
We're renting our camper and have had quite many families and couples in our camper during 2020. I knew it was only a matter of time until the hinge was going to fail and sure enough, when I had a look, it was already cracked and close to breaking.
A new table at VW is about 450 euros, so I figured I'd try to fix it myself before buying a new one.
It much simpler than I though. Only basic tools needed and could find all the parts in my local hardware store. I started by removing the cracked part of the plastic and drilling out the two rivets seen in the top image. I then bought a simple hinge for a door that you would have in a house. Below are some pictures of the parts that I used. I had to drill an extra hole in the door hinge. I also drilled holes in the table. I added some contact glue for extra stability and the bolts are of a locking type. I found inspiration to this solution in a French forum, but it wasn't easy to find. Though this might help people since this is a really common problem. There are some cracks in the visible table surface, I hope it will still hold
