AndrewBye
Hope I’ve posted in the right place. Upgraded our se 180 this week for a newer t6 ocean and really pleased, until opened sliding door this morning and handle became completely stuck open and now door won’t close. Can anyone help. Thanks
Bit more info would help.Hope I’ve posted in the right place. Upgraded our se 180 this week for a newer t6 ocean and really pleased, until opened sliding door this morning and handle became completely stuck open and now door won’t close. Can anyone help. Thanks
Think you will find that if you can pull the door nearly closed, the power soft close (present on most Oceans will do the rest.It’s a manual door and still slides. The handle is stuck out and not retracting.I have tried to post a picture. Is it safe to push handle back in? And if not if it will close will it be ok to drive to garage? Thanks
Is the door now closed and latched in the opening or free to open if you push from inside?
Don’t know the cable layout inside the door but if the internal door release functions correctly (ie operates the lock and you can manually shut the door again from outside) then does sound like the outer handle has become detached from the operating cable.All closed fine from inside just feels like handle not attached to anything behind.
Out of interest @AndrewBye was the door handle frozen when you opened the door?Hope I’ve posted in the right place. Upgraded our se 180 this week for a newer t6 ocean and really pleased, until opened sliding door this morning and handle became completely stuck open and now door won’t close. Can anyone help. Thanks
Good to hear that it will be coveredNo not frozen, we only picked it up on Wednesday the dealer has offered to cover all costs of repair. It dealt a little loose on operation and then just stopped working.
