GrumpyGranddad
It will be interesting to see if there is a difference in actual road speeds between vehicles as is the case with HGV's.The van will be able to let you know soon, if the UK adopts the EU Rules:
Mandatory speed limiters on EU cars from July 2024 | Autotrader
All new vehicles sold in Europe – including Northern Ireland but not Great Britain – will be fitted with a mandatory speed limiter from 2024 to keep cars within the speed limits and boost road safety.www.autotrader.co.uk
Regarding the ‘gong’.All T6.1 Calis have the required speed limiter already that meet the 2022 requirements. The automated intelligent system isn't needed until 2024.
The 2024 legislation also allows you to break the speed limits with an override it will however be accompanied with warning gongs etc.
The T6.1 limiter ( and that fitted to our Mercedes) work like this already but without the gong. Kickdown on the accelerator lets you exceed the set limit but it is a deliberate action, you don't just creep over by accident.
I've got it set to just visual, as the gong was jarring. I have it set to 5mph over too, which is great for the motorway, but not in town. Be good if a 10% over speed limit warning was an option.Regarding the ‘gong’.
In our 6.1 with traffic sign recognition we have set it up to give both a visual and audible warning if we exceed the speed limit. Very useful aid.
I bet that within the next 5 years every car will have a permanent system and it will be against the law to override it. So get used to max 70mph.
or 50mph as work begins on "smart" motorways V4.8
Yes. Why v4.8Work has just been suspended on all new smart motorways.
Sometimes I think I’m alone in loving smart motorways - the ones where the hard shoulder has been turned into a permanent running lane. Not the hybrid mess around Luton.
@GrumpyGranddad do you know if the traffic sign recognition works in France? I ask due to the many differences in the way that the 80kph limit is implemented or not as each department sees fit.Regarding the ‘gong’.
The northbound M6 just before spaghetti junction is particularly frightening, the hard shoulder is flanked by a concrete parapet with a drop on the other side, so there is not even refuge for passengers when it is used as a running lane. Frightening - I can't understand why it is allowed.Sometimes I think I’m alone in loving smart motorways - the ones where the hard shoulder has been turned into a permanent running lane.
Cars tend not to break down with the frequency they once did. And if you do break down, there must be a good chance you can coast or limp to the nearest refuge, unless some catastrophic failure like a lost wheel. But in those extreme cases you might not make it to the hard shoulder on a dumb motorway.If you had ever broken down on one I'm not sure you would like them so much.
I hadn’t understood that about the Luton smartie. Thanks for explaining. If I recall correctly there are sections around Luton of permanent hard shoulder running and sections of peak hard shoulder running.The ones round Luton are a safer implementation, if traffic is fast flowing the inside lane is a hard shoulder. When traffic is heavy & slow moving the lane is opened up to become a running lane.
The inside lane/ hard shoulder is never used as a running lane with a speed limit higher than 50mph.
For 2/3rds of the day & most importantly normally overnight in the dark that lane is hard shoulder only.
Most IC vehicles that break down can coast to a refuge but not the case with an EV, so I am led to believe. Also, in common with most automatic transmissions they must be towed " wheels Up" as on a trailer.Cars tend not to break down with the frequency they once did. And if you do break down, there must be a good chance you can coast or limp to the nearest refuge, unless some catastrophic failure like a lost wheel. But in those extreme cases you might not make it to the hard shoulder on a dumb motorway.
The same applies to the parallel southbound lane.
I think that is correct. The only times that I have used it have been in heavy traffic when there has been a 50m.p.h.limit. On one occasion I had to follow a slow moving car showing hazard flashers until it reached the A38 junction; I was unable to change lanes because of the traffic density (as was the traffic behind me). The experience was a little disconcerting.If so, is this the type [mention]andyinluton [/mention] was referring to which is only used when the speed limit is 50mph or less?
That's it - by default its a hard shoulder but opened in dense traffic times to become a running lane. In my opinion, still not ideal, but safer than having four full time running lanes & then trying to stop people using the inside lane if someone has broken down.This section?
Hi @rod_vw@GrumpyGranddad do you know if the traffic sign recognition works in France? I ask due to the many differences in the way that the 80kph limit is implemented or not as each department sees fit.
Others living in France or have been recent users of French roads may be able to confirm or deny.
