Yes.Looking at options to upgrade the standard head unit in a T6.1 with a factory reverse camera. Must be compatible with the steering wheel controls, praking sensors and the reverse camera. Is there such a thing?
absolut5.co.uk
See my Post 2. They only do 3rd party, not OEM.Both of those look more tailored to retrofitting VW parts, which is not my aim. I am really looking to identify a suitable aftermarket headunit that will retain the integration with the existing steering wheel and camera.
Agree with WG re Absolut5. We used them for a special unit for our T6, very happy.Both of those look more tailored to retrofitting VW parts, which is not my aim. I am really looking to identify a suitable aftermarket headunit that will retain the integration with the existing steering wheel and camera.
They would supply the unit, together with all leads etc to make it plug and play . Your choice.Thanks, plan would be to fit myself - so don't really want to take time getting advice from a company that I probably would not use (unless price was competitive on a supply only basis). Was hoping for a recommendation of a unit someone has used that is compatible.
Kenwood DMX8019 + Kenwood interface leadThanks, plan would be to fit myself - so don't really want to take time getting advice from a company that I probably would not use (unless price was competitive on a supply only basis). Was hoping for a recommendation of a unit someone has used that is compatible.
Seems like a lot of hassle just to get wireless. Wouldn't you better off keeping the factory head unit & adding something like a "carlinkit" which is designed to be left plugged into one of the USB sockets instead of your phone, making your phone a completely wireless connection.Thanks, will check it out. Assume you need some sort of interface cable for the reverse camera as well (or that it is included in the harness you mentioned).
Really only looking for wireless Airplay, got used to it in my Mini, so much easier than the system in the Volvo!
Would really like a digital dash, but as the camper doesn't have the discover media unit in, tat would be an expensive upgrade!
There is a standard input on the back of the unit for the reverse camera. Also displays the parking sensors (as we don’t have a camera fitted).Thanks, will check it out. Assume you need some sort of interface cable for the reverse camera as well (or that it is included in the harness you mentioned).
Appologies I mis understood your quote:Both of those look more tailored to retrofitting VW parts, which is not my aim. I am really looking to identify a suitable aftermarket headunit that will retain the integration with the existing steering wheel and camera.
I retro fitted a genuine VW T6 rear view camera a couple of years ago. Bought on ebay from Germany.Thanks, plan would be to fit myself - so don't really want to take time getting advice from a company that I probably would not use (unless price was competitive on a supply only basis). Was hoping for a recommendation of a unit someone has used that is compatible.
See this perhaps more cost effective than some of the above options https://vwcaliforniaclub.com/threads/reversing-camera.14155/Looking at options to upgrade the standard head unit in a T6.1 with a factory reverse camera. Must be compatible with the steering wheel controls, praking sensors and the reverse camera. Is there such a thing?
Turns out there aren't so many options on the T6.1 without cutting plastic behind the dash, as the T6.1 has a two part ICE system, so can only take a half depth unit without it.Kenwood DMX8019 + Kenwood interface lead
will give you the features that you are looking for.
Absolut5 can supply both and give excellent support. They can also give advice on other units.
Other suppliers will generally try to sell you a non Kenwood interface lead which will result in inferior graphics on the head unit, will not display Radio station on MFD, requires splicing wires etc…rather than just being plug + play.
I thought you already had a screen and parking sensors and you were just trying to get a camera that would show up on the existing screen with the sensors overlaid like this i.e. as per factory spec https://vwcaliforniaclub.com/threads/reversing-camera.14155/ ?Turns out there aren't so many options on the T6.1 without cutting plastic behind the dash, as the T6.1 has a two part ICE system, so can only take a half depth unit without it.
Spoke to Absolut5, and no option available at the moment that will fit (without cutting) that can work with factory camera and wireless carplay!
No.I thought you already had a screen and parking sensors and you were just trying to get a camera that would show up on the existing screen with the sensors overlaid like this i.e. as per factory spec https://vwcaliforniaclub.com/threads/reversing-camera.14155/
