Stu@rt
Hi Holly, take a look at Will's @itguy video here.Hi Stuart, sometimes it works and sometimes it doesn’t! If I can’t get heat continuously or heat immediately to work then the key fob usually does but only for under two hours and if I use it in the evening and again in the morning and don’t drive anywhere it won’t work the next evening. What are ‘rules’ about how many times each of the different settings work without moving? The manual is not helpful..! Thank you Holly
Explains the nuances really well.
