Kitchen left hand sliding door door catch replacement.
seasiders1
seasiders1
West Sussex
T5 SE 130
Has anyone tried to replace the left hand kitchen door frame catch. Mine has split and the door is now rattling. I’ve removed the circular panel which leads to the lower part of the fridge but cannot get my hand up and behind to undo the screws holding the catch in place…..I think maybe the fridge has to come out? Perhaps I’ll just drill and put a self tapping screw through the front of the upper part in the photo (and return the replacement I bought)…anyone have any other ideas?
Thanks, Peter
Thanks, Peter
Are you sure it is screwed in?
This parts diagram doesn't show any screws or rivets. Part 13
I shattered mine and stuck it back together with gorilla superglue.
Part of the fitting that was attached to the sliding door was also broken in the smash and i fixed that with the same.
I don't recall there being any screws in the frame or door. In fact the fitting in the door was weird to fit back on the recess for it when I'd finished glueing it together.
It all started when something on the shelf in the cupboard fell over and jammed the door and there was no way I could work it lose. I resorted to brute force I'm ashamed to say but gorilla glue (as often) saved the day. I was fortunate to find/save all the pieces.
Thanks for this WelshGas, that’s very helpful. I have checked the part number on this diagram against the item I bought and it’s the same. It has two lugs and two screws to secure it . I think I’ll break off the old one and glue in the new one.
Thanks Barry, I think I’ll break off the old one and glue in the new one with gorilla glue…
It should not be a huge job to dismount the fridge and lift I up? I think there is a description in her on how its done … maybe worth a search.
I am looking for the actual door latch mechanism (left door). Where essentially you press to open the sliding door of the kitchen, the piece that latches and keeps the door closed is broken. Can't find part number
I used a putty/plastic/adhesive called Sugru to fix my door broken door catch....it has lasted 8 years so far!
Bit of a challenge as I performed the fix purely by feel. However currently working....lunch in glorious sunshine Loch Carron.
Picture is of repair RHS unit door. Not of Strath Carron!
Any idea how you take the sliding doors out of the runners?
Does anybody know the part number and supplier details for a 6.1 version of the LHS kitchen cupboard door catch?
It is significantly different from that in the diagram above. And I’ve snapped it :headbang
The catch is 7LA 068 027A
The cupboard door handle is 7LA 068 025B
I bought mine from Campervantastic
Fabulous. I’ll check it out :thumb
Edit…checked, right fit, ordered, :cheers
7LA 068 027A left hand door catch - accessed by removing the fridge. £40 for a £2 piece of flimsy plastic
Thanks, Peter
If you want to do it properly, it's a fridge out job i'm afraid, i have done a few of them.
