A Favour Required Please
Jester
Dorset
Cali now sold
Are there any members living or close by to Caravan Accessory Shop
42 Cromer Road
West Runton
CROMER
Norfolk NR27 9AD
As this is the only place to purchase the uniQick Elbow, unfortunately they do not send via post, I have the standby pump in case of the existing failing but not the Elbow.
Reich UniQuick Elbow Adaptor 12mm
Of course I will reimburse you for your trouble, just I’m in Dorset and Norfolk is to far to travel for £3.75.
Anyway thanks for reading.
Will
Another option might be to get a 12mm equal elbow (john guest) and a barbed adaptor. If it’s just for emergency/back-up.
Sorry I’m not near Norfolk, so can’t offer to grab one.
Good luck.
Good luck.
Thanks Mr T John was correct so just about to order from Amazon.
No problem, just check as the part number you quoted is different to what has been found on Amazon.
You asked for Reich 533-8231 the amazon item is 533-5231.
No idea if they are the same/different but probably worth a punt for the cost.
Hi, yes checked that the description refers to the original part number so think it should be ok, although £17 delivered, first they want our fish now they rob me,
