stefmarz
Hi there,
I would like to ask you an explanation on the Auxiliary Heater which I could not find anywhere as for the T6.1 apparently they changed slightly the system.
There are 2 main modes: Heat Continuously or Heat Immediately. First of all, I guess the first one will keep heating until you turn it off and the second one will heat for 60 minutes or so (depending on the timing you put in the settings). Correct?
In both methods, the heater will start heating and then after 20 min or so, it stops.. then consequently the temperature drops in the van.. and then it starts again. So it is very intermittent, I could not find the way to make it run continuously without stopping. Is this normal?
Thanks a lot for your help but I could not find this answer anywhere.
Stefano
Stefano
