D
Hi Dominichayhoe,I just took the details off my ‘Leisure Battery’ under the bonnet and it’s markings online show that it is not a leisure battery but a start battery?
Maybe they took a proactive decision to go with this as the best compromise, as one that's need for the above purpose and the deep cycling somewhat allowed by the AGM factor.Hi Dominichayhoe,
Yes it is a START battery.... This is what I've found on the VARTA web site:
"VARTA® Silver Dynamic AGM batteries are perfect for advanced start-stop systems in which the battery needs to be quickly recharged through the energy provided by the regenerative braking systems."
Dynamic AGM 595901085K262 guide | VARTA Automotive Batteries
Dynamic AGM 595901085K262 options ► Review key differences with VARTA insight and choose a battery that suits your needs Learn more today.www.varta-automotive.com
who am I to correct you, just wanted to point out that it is in effect a battery to start the engine,Maybe they took a proactive decision to go with this as the best compromise, as one that's need for the above purpose and the deep cycling somewhat allowed by the AGM factor.
Thanks for pointing out my grammatical error and putting it in capitals too, I'm sure no one knew that I meant starter as opposed to start.
That's nice. That's not the battery I have under my bonnet though. Mine is as per the OP.According to my local battery importer, the Varta Silver Dynamic AGM short code F21 (start battery) 80AH 800 CCA and the Varta Professional Dual Purpose AGM short code LA80 (leisure battery) 80AH 800 CCA are exactly the same battery sold under different labels…
What battery have you got fitted as the Leisure Battery?That's nice. That's not the battery I have under my bonnet though. Mine is as per the OP.
He's just told you! same as the OPWhat battery have you got fitted as the Leisure Battery?
Sorry meant Engine Battery?He's just told you! same as the OP
On a GC the leisure battery is in the engine bay, & the engine battery is under the seat.
Correct.I have two AGM's. So... is the battery under the bonnet the starter battery and the battery under the driver's seat is the leisure battery?AGM batteries are used by VW as leisure batteries, the leisure battery is the same as the starter battery as supplied from the factory.
Surely that is a bit nuts! I have had so much conflicting information, how can I be sure that is correct?No, somewhat counter-intuitively the one under the bonnet is the leisure battery. The one under the left side (UK passenger) seat is the starter battery.
Disconnect the negative terminal from the battery under the bonnet and see if you’re van starts !Surely that is a bit nuts! I have had so much conflicting information, how can I be sure that is correct?
This is true for the car in your avatar picture, but not for the Vw California..No, somewhat counter-intuitively the one under the bonnet is the leisure battery. The one under the left side (UK passenger) seat is the starter battery.
The picture in his Avatar is of a Vw California - just a different model to the one you have.This is true for the car in your avatar picture, but not for the Vw California..
This is a Grand California thread, GC600 and GC680 .. what vehicle are you referring to?Surely that is a bit nuts! I have had so much conflicting information, how can I be sure that is correct?
The picture is of my VW Grand California GC600, and this is the VW Grand California thread of the forum so I have assumed the OP is asking a question about a Grand California.This is true for the car in your avatar picture, but not for the Vw California..
I guess that was a stupid question! I am just wonderfully stupid. Thanks for your answer, I'll do advised. But I have to say none of the mechanics have suggested this as the answer and it is so obvious.Disconnect the negative terminal from the battery under the bonnet and see if you van starts !
If not it’s a starter battery , if it does start it’s a leisure battery
Read my strap line: No question is a stupid question…….I guess that was a stupid question! I am just wonderfully stupid. Thanks for your answer, I'll do advised. But I have to say none of the mechanics have suggested this as the answer and it is so obvious.
Notice the forum in which it's posted.This is true for the car in your avatar picture, but not for the Vw California..
