Many people advocate rotating Front and Rear tyres to even out the wear. However I have not adopted this practice on my 4Motion California and here is the evidence.
Vehicle - 180 4Motion SE Fully loaded for camping apart from some clothes and filling the Tank when actually camping. There are only 2 of us. Used as a Daily Driver. Milage covered since Tyres fitted 17,643 miles.
Tyres - Goodyear Cargo Vector 4 Seasons M&S 235/55 R 17 103H. Rear 44 psi Front 38 psi
Tread Depth measured with a Digital Gauge a 2 points 90o apart hence 8 points / tyre and then Mean Calculated.
New Tyres have a Tread Depth of 8 - 10mm for most tyres
Legal Limit is 1.6mm but most Tyre Experts suggest changing at 3mm.
Front Nearside 5.86 mm Front Offside 6.40 mm
Rear Nearside 6.26 mm Rear Offside 6.31 mm
It is well known that the Front Nearside can wear faster than the opposite side because we drive on the Left in the UK and Left turns are more acute than Right turns hence more scrubbing/wear of the tyre. The opposite is true in those countries that drive on the Right.
So - I will not be rotating Front to Rear BUT might consider swapping Front NS and Front OS, but there is a counter argument to doing that in that tyre wear into their position and there can be a difference in efficiency when moving them around until they have bedded in.
Seeing as I generally change tyre when they get to 3 - 4 mm tread depth I may just change all 4 when the Front Nearside gets down to 3 mm.
This may not, and probably does not hold true for the 2 Wheel Drive equivalent vehicle.
