alexwhill
- Messages
- 35
- Vehicle
- T7 California Ocean 4 Motion
Hi Alexwhill,View attachment 86061What’s the best cure for a saggy arse? Siekel seems a bit extreme .. anyone got any experience of a bum lift?
Hi @alexwhill , this has been covered in the past but if you look at the side bar on your van relative to the ground, it is parallel. Meaning that your van’s arse is NOT sagging. It’s an optical illusion since, as others have mentioned, the front wheel arch on a Cali’ is cut higher than the rear. If you lift the rear the van won’t then be flat on the ground. Try a spirit level on the floor in the living area.View attachment 86061What’s the best cure for a saggy arse? Siekel seems a bit extreme .. anyone got any experience of a bum lift?
The arse high position also raises the center of gravity at the rear, one of the most destabilizing things you can do to such a heavy vehicle.Whatever you do. Don’t let CRS Performance install spacers on the rear springs. It might look level from the outside, it’s not.
The van ends up arse high. Which means, the van is never level for camping. I sleep up in the roof, which means I always need levelling chocks. I’m about to have them removed.
Give me arse sag any day…
He has 17" wheels which are a size option with Alloys on T5's.I think the oversize wheels on your van are adding to the illusion caused by front wheel arch being higher than the back.
I did a fair bit of messing about with my T5.1 rear suspension before I was happy.
In the end I stuck with some heavy duty rear springs (3 grey stripes) that lifted the rear very slightly (about 5mm) and reduced the saggy bum a bit but without making the van feel nose down.
I also tried some t32 (4 grey stripe) springs but they lifted the back end too much for my liking and felt unbalanced compared to the original springs on the front.
Changing rear springs is a fairly straightforward DIY job.
I also fitted heavy duty shock absorbers which seemed to make a big difference to ride quality but I might have got a similar improvement just by replacing like for like as after 5 years the original ones had seen better days.
CRS Performance claims on the T6 Forum that all vans come raised at the rear from the factory, and they are duplicating that slant from back to front as measured from the door sill to ground at back and front.They have not understood that empty Transporters are higher at the rear precisely so that they will be level when loaded with, for example, California equipment. The lower cut rear wheel arch is designed to disguise the raised rear when a Transporter is empty, so when the van is level the rear arch will be lower.
I would doubt very much that the rear arch is 'designed' to disguise the ride height. Merely to carry out its function as a mudguard.The arse high position also raises the center of gravity at the rear, one of the most destabilizing things you can do to such a heavy vehicle.
Spacers under the springs are the answer.
It depends entirely on how thick the spacers are.Not on a California.
I would guess Volkswagen have already calculated max load with the limited space available.
100%
Spring spacers = uneven ride height on a California…
That would explain why T6.1 Californias are coming out of the factory at over 2m high.Minor changes between T6 & T6.1 seem to have tipped it into weight range 4 and as a result the 6.1 has stiffer springs on the back.
Agree, somewhere in that thread or a similar one a T6.1 owner posted the type of spring (number & colour of stripes) that they had on their van which confirmed the t6.1 had moved up to the next weight range and had stiffer springs as std than the t5 / t6That would explain why T6.1 Californias are coming out of the factory at over 2m high.
6.1 Cali height, over 2m
A couple of members have just measured their 6.1 Cali Oceans at between 2.03m and 2.04 m at the rear, with a difference front to rear at the door sill and side body line of 40-50 mm. This is higher than previous Calis. Have other 6.1 owners, Ocean or Beach, seen this? This video shows the...vwcaliforniaclub.com
Ahh! You put wheels on first comment.Those don't look like standard profile tyres on the wheels, here's an old photo of mine with the same rims & standard size tyres.View attachment 86082
Having oversize tyres on both back and front will have no effect on arch gaps.
In this case the issue is the difference between front and rear arch heights--rear looking lower ie saggy.Of course it will have an effect! It won't change the slope, but a bigger tyre will fill the gap more.
Agreed.In the original photo the van is parked nose-up on a slight slope which doesn’t exactly help.
