Defender90
Can anyone help I cant get the sat nav to follow the route and it doesn’t orientate in the direction of travel ,it works on the speedo central display
Hello, did you get this fixed as it sounds like the same problem that I now have?Can anyone help I cant get the sat nav to follow the route and it doesn’t orientate in the direction of travel ,it works on the speedo central display
On the T6, the likely issue is the NAv aerial has failed , cheap to fix by replacing the aerial if it’s within your skill setHello, did you get this fixed as it sounds like the same problem that I now have?
