I
ianm
I am trying to decide on the simplest way of charging an eMTB battery when not on EHU. I have seen various threads that talk about wiring in a separate inverter to the leisure battery under the passenger seat, and it may well be that will be the way I have to go. However, I have just watched the video mentioned in another post which says that the inverter on the left of the drivers seat can handle 300W (we have a 6.1 Coast from 2021) and I wondered whether that would be a simpler solution.
My battery charger (for a Yamaha PW-X2 motor) is rated at 1.4A for UK 220/240V. That, I think, is just over 300W depending on actual voltage if I have understood the conversion, which I may well not have! There is another post by @Lightning that indicates it worked for his electric Brompton with greater power usage if the engine is running. What damage, if any, am I likely to do if I plug it in and try? Is the worst that a fuse may blow or just that it will charge more slowly, or not at all? There is no 12V charger option for Yamaha motors.
I realise that I am more than likely to add solar at some point, but am trying to cut down on the extras at present: one can spend worrying large amounts even AFTER buying a Cali! Even being able to charge the bike battery whilst driving would be a start.
Ian
Ian
