capt kirk
You might not have red squirrels, but you do have loads of red kites, which are more visible than squirrels, and just stunning to watch.
We do, and enjoyable watching them, but a bit too many really.
and someone on the right is ensuring that the MOT is done correctly. Woof Woof!
Love a hill climb. We have a good one near us at Harewood. Always lots of interesting stuff to look round.Took my grandson to the Kop Hill Climb. Really busy, some fabulous cars (and bikes), great fun. Nice weather too
Since we don’t use it, I was thinking of redeploying the child safety net for the same purpose as your device. Not looked at the feasibility yet. Anybody done it?Fitted this to stop stuff falling out when opening tailgate.View attachment 85537View attachment 85538
Yes, 8,000 miles on a rat tail - similar to where you have the puncture on the Cali. 7,000 miles on a motorcycle rear tyre again, with a rat tail. No issues.Can I rely on that? Anybody with similar experience?
Which kit did you buy Andy @andyinluton . I agree it’s probably worth carrying one.In the centre of the tread like that it should be fine as long as the tyre wasn’t driven on whilst flat.
Ive never had to use one whilst out and about but do carry a repair kit with the plugs just in case.
I carry one of these.Which kit did you buy Andy @andyinluton . I agree it’s probably worth carrying one.
Thanks @Alied . That looks very different than other kits on the web (and more expensive). Have you used it yet? I assume that the brass pointed end remains inside the tyre?I carry one of these.
Dynaplug Pro Xtreme Tubeless Tyre Repair Kit - Aluminium [DP-XT-AL] - £77.95 : Tyre Repair Kits, Repairs any tyre in minutes without tyre removal
Tyre Repair Kits Dynaplug Pro Xtreme Tubeless Tyre Repair Kit - Aluminium [DP-XT-AL] - The Dynaplug® Pro Xtreme has a large end cap that allows for extra leverage when making repairs on heavy duty tyres. The cap unscrews for access to a waterproof compartment for secure storage of the supplied...www.tyrerepairkits.co.uk
No I haven’t used it yet. I did watch quite a few videos on YouTube before I purchased it. The advantage over other similar products is that you don’t have to ream the tyre thus making the hole bigger before inserting the plug. Yes the brass tip stays inside the tyre and if it does dislodge with brass being a soft alloy in theory it shouldn’t damage your rim. Cheaper Dynaplugs are available but I went with this one as it has a large surface area so it should be easier to push the plug in to the tyre.Thanks @Alied . That looks very different than other kits on the web (and more expensive). Have you used it yet? I assume that the brass pointed end remains inside the tyre?
A very cheap ebay kit.Which kit did you buy Andy @andyinluton . I agree it’s probably worth carrying one.
We had a similar tyre penetration.Drove to Aldwickbury Park Golf Course to play badly
BUT en-route I picked up a bolt in my nearside rear tyre! So a question for those with experience. The tyre repair shop to my surprise didn’t even need to remove the wheel/tyre. Just jacked it up and removed the offending bolt and then pushed in a braided plug. I asked the guy if there are now any limitations with the tyre i.e. speed and he said no. Can I rely on that? Anybody with similar experience?
Thanks @SusiBusWe had a similar tyre penetration.
A VW dealer in Poole said we needed a new tyre, but were unable to get hold of one to match. So when we returned home, took it into the local tyre fitter, they said it was perfectly ok to plug as it was in the centre of the tread. It cause no problem afterwards.
Your's looks like it may be a little bit different, as there appears to be a cut adjacent to where the bolt has penetrated, but if it is only in the surface of the rubber, can't see it being a problem.
Thinking back, l did watch them do the repair, I think the plug had a patch attached to it, and was applied from the inside, so was like a double solution. Agree, you need to feel confident that it is a safe solution, otherwise and new tyre is the best option.Thanks @SusiBus
Having had a chat with them, I’ve booked it into a local tyre centre tomorrow morning. They are taking the tyre off to have a proper look and if possible will apply an internal patch which is an approved fix. If not it’s a new tyre. I just need to be sure it’s as safe as possible before any long motorway journeys. Wouldn’t feel happy doing 70 with a plug.
| Manufacturer/Brand | Speed Rating | Multiple Repair Locations |
BFGoodrich | Maintained | 3 repairs, minimum 90° apart |
Bridgestone | Voided | 2 repairs, must be a minimum of 16" apart |
Continental* | Maintained | Repairs cannot overlap |
Cooper | Voided | Repairs cannot overlap |
Dick Cepek | Voided | Repairs cannot overlap |
Dunlop | Maintained** | Repairs cannot overlap |
| 1 repair, H and above | ||
Falken | Voided | Repairs cannot overlap |
Firestone | Voided | 2 repairs, must be a minimum of 16" apart |
Fuzion | Voided | 2 repairs, must be a minimum of 16" apart |
General* | Maintained | Repairs cannot overlap |
Goodyear | Maintained** | Repairs cannot overlap |
Hankook | Voided | Repairs cannot overlap |
Kumho | Voided | 2 repairs, minimum 180° apart |
Laufenn | Maintained | Repairs cannot overlap |
Michelin | Maintained | 3 repairs, minimum 90° apart |
Nexen | Maintained | Repairs cannot overlap |
Pirelli V and Above | Repair Not Endorsed by Pirelli | 1 repair |
| H and Below | Maintained | |
Power King | Voided | Repairs cannot overlap |
RIKEN | Maintained | 3 repairs, minimum 90° apart |
Sumitomo | Voided | Repairs cannot overlap |
Toyo H and Above | Reduced to H. Voided if more than one repair. | 4 repairs, minimum 90° apart |
| Below H | Maintained. Voided if more than one repair. | 4 repairs, minimum 90° apart |
Uniroyal | Maintained | 3 repairs, minimum 90° apart* |
Vredestein V and Above | Repair Not Endorsed by Vredestein | 2 repairs |
H and Below* | Reduce 1 speed rating per repair | |
Yokohama | Voided | Repairs cannot overlap |
| *Voids materials, workmanship and tread wear-out warranties. **Only 1 repair permitted to retain H and above speed ratings. |
