Borris
I am wondering if anyone can advise me on a clutch issue that my daughter and her husband have just experienced with their 2003 T4 Autosleeper motorhome. Jon our son in law has just telephoned to say that the said vehicle has been towed to their garage of choice after the clutch pedal went to the floor and he was unable to get it into gear.
The garage concerned have said that the vehicle requires a new clutch, dual mass flywheel and clutch slave cylinder. Since the clutch was working perfectly with no juddering up to the point of failure I cannot see why the vehicle would require either a new clutch or dual mass flywheel. I have had this same issue on other vehicles in the past and it was then purely a hydraulic failure resulting in a new clutch slave cylinder and fluid replacement.
This isn't the first time they have used this garage and it won't be the first time that they have been talked into having unessesary work done.
My questions are:
1. Does a 2003 2.5 Tdi manual T4 even have a dual mass flywheel?
2. Where is the clutch slave cylinder located and can it be replaced easily without stripping down the clutch assembly?
I am no mechanic but I do have some experience gathered over years of messing about with vehicles. Therefore I am rather sceptical about this garage's list of work required and am seeking advice from any knowleable T4 owners. The vehicle has low mileage for the year, sub 100,000 miles. From memory around 75,000.
Many thanks in advance. All comments gratefully received.
P.s They are due to go off to Scotland at the beginning of October so this hasn't happened at a very convenient time. I am wondering if it is just a slave cylinder that requires changing and if so whether it is a fairly straight forward job?
My questions are:
