Amonkeyhint
Since getting my cali, I’ve wanted to change the colour of the roll out awning to black from silver. I looked at a few options from replacing it (about £800), wrapping it (£250) and spraying it myself.
I decided to buy some cans of plastidip, since it is removable if I mess it up.
removing the awning is really easy, just unroll the awning fully and remove the two screws attaching to the rail. There is a single screw in each end cap to remove too which need to be done when the awning is fully extended (glad I realised this when it was still attached to the van).
Once the screws are removed, the awning just lifts off where I led it down and started masking off the bit I didn’t want black.
I found doing a few very light coats to start with and then a relatively heavy final coat gave the best finish.
I took the opportunity to spray the silver awning rail on each side black to suit.
Due to the awning size, it is quite trick to get an even finish (partly because I was fumbling my way around) and wasn’t paticularly happy with the finish once on the van.
At this stage, I partly rolled out the awning, covered the bits I didn’t want overspray on and did it in situ - I found this gave a much nicer finish as I could spray in one continuous run.
Fairly happy with the finish, it would probably be better if I had done it before, but I can’t complain for a first time.
